Connect Nokia 6600 to a computer
Hello Techyv
I want to know How can I connect my Nokia 6600 Phone to a computer while using a Bluetooth? And how can I connect my phone to the net using a computer? so any help with these questions
Thanks
Hello Techyv
Thanks
Hi Whopperman,
To connect your phone to your pc you need to install
nokia pc suite for your nokia 6600. You can download yourÂ
nokia 6600 pc suite from the nokia official site:
https://www.nokia.com/en_us/phones/support
Once you have installed the suite, follow the guided instructions.
Your pc needs to meet nokia pc suite requirements which are,
Operating System:Â Windows ME and higher versions of windows.
                                   Minimum of 110 MB free space disk space.
Synchronize your phone to the pc using the pc suite you have just downloaded.
Go to connectivity on your pc suite window, you will have to tick connect via blue tooth.
Note: You may have to adjust your fire wall settings if you still not able to connect.
Kind regards
John Handy
Dear John Handy, You gave a fruitful solution. Your solution helped me and I am now able to connect my phone. Thanks a lot. I appreciate you.
