Connect a PC using LAN mode
Hi friends
Please let me know how to connect a PC using LAN mode. I have been trying many times but still cannot connect.
Thanks
Hi friends
Thanks
Just connect to PC with LAN cable and after that go to "Network" option for Windows 7. If you are a user of XP, then go to "My network places". There you will see the connected computer. For Windows 7, you need to change a setting. Go to “Network & Sharing Center", click on "change advance sharing setting". Put all the options like the picture below. Now it's done
Hi Scott,
I can help you connect two computers with a LAN cable. Please follow these steps.
* You will need a cross cable to connect to a computer.
* Set the IP addresses for both computers.
* Make sure that the Workgroup on two computers are set to the same.
* Now you should be able to see the shared directory under ‘network’.
This will surely fix your issue.
Skarbos
Jay.
