Connect two computers without using cable
Well Elvis, you can definitely do that. For that you can set up a wireless network for the two PCs to get connected. What are the operating systems that you are using on the two PCs by the way and what are their versions. If you can tell me that, i can tell you step by step process of creating and setting up a wireless network.
Do you happen to have a wireless router? If yes, then setting up a connection will be very easy for you and you can connect the two PCs to share the data and documents with each other. You will also be able to share printers, faxes as well as internet connection on both the PCs.
Another way to connect the two PCs (if you want to connect them say only for a file transfer) is to use Bluetooth. It has low data rate but it will allow you to connect the PCs and share the files at your will.
Its possible to connect two computers using wireless,you need to give me more details:First which platform are you using,is it Linux or Microsoft windows?
Secondly is it desktop or laptop since configurations may differ?
Thirdly do you want to use wireless connection of which type WEP or WPA or Bluetooth?
But the general involvement is configuring your IP address to be in such a way on the same network.
Please provide me with more details mentioned above and i will show you STEP by STEP of setting up.
Thanks
Thank you Richie Kil and Bonifacekimeu. I contacted a friend and have him do that. He used SEO network applications that runs online. But thank you for your help. I'll sure ask you if I have problems again. Great job TechyV!
Notifications
