Connect a VPN with simulation games lan
I am trying to connect LAN for simulation games with VPN server, but VPN stopped all the process of LAN. How can I use LAN with VPN?
Hey Chesley,
Do the following and you will have no problem playing simulation games.
1. I am guessing that you use Windows PPTP VPN for accessing, change one small setting.
2. Navigate to the network connections folder, right click on the VPN connection and click properties.
3. Click the Networking tab.
4. Select Internet Protocol (TCP/IP) from the list and press the Properties button.
5. Then press the advanced button.
6. Uncheck the "Use Default gateway on remote network"
7. Click OK, OK, OK.
Reconnect to your VPN.
Cheers.
Notifications
