Connecting 2 Computers without a networking hub
Experts is there any way to connect 2 computers without a networking hub? Please kindly help me if there is any solution.
Ms. Shina Lopez. Here is a solution for this.
Step 2:
Plug in the cable in each computer's Ethernet card. Now you also need to provide static IP addresses in both Computers. To do this, right click on My network places and select properties. Then right click in Network Connections on your network connection and select properties again. In the general tab, middle of the window highlight Internet Connections TCP/IP and press the properties button below it. In the window that appears, select "use the following IP address" and enter in PC # 1, 192.168.1.2 for the IP address, 255.255.255.0 for subnet mask, 192.168.1.2 for default gateway; no need to address the DNS. Save and close out of this.
Thank you kdawood. I didn't make a cable by my self i just bought from a computer store. And I enter all the information about the IP addressing and its done.
Thank you very much.
