Connecting Galaxy S5 to my laptop and how to maximize it
Hello!
I am having trouble with my phone lately. I have issues of having automatic restart and shut down with it. I am having problems also connecting it with my pc. Most of the time, the most annoying with the issues I am experiencing is that it keeps on disconnecting with WiFi access. Can you tell me what could be the cause of this problem? Can you show me or give me instructions on how to resolve this problem? Can you provide me also alternative ways to eliminate it?
Thank you!
Answered By 0 points N/A #191985
May be that there are some errors in the OS.
So try following these strategies,
  • Restart the device (because a refreshing reboot has the capability to fix certain system issues)
  • Perform system updates regularly and any other application updates if available
  • Identify & removing the applications with issues
  • Do a system back up where these issues were absent
If all the attempts prove useless, it is advisable to reset the default factory settings so that the device is freed from any processes related to the issue.
Best Regards!
Answered By 590495 points N/A #318708
If you are having problems with your phone, try factory resetting it from Recovery Mode. With the phone completely off, press and hold the Volume Up, Home, and Power buttons simultaneously until the Samsung Galaxy logo appears. When the logo appears, release the Power button but continue holding the other keys. When the Android System Recovery screen appears, release all buttons.
To navigate between the options, press the Volume Up/Down buttons. To select or Enter, press the Power button. Now, press Volume Down and go to “wipe data/factory reset” then press the Power button to select. Next, press Volume Down and go to “Yes — delete all user data” then press the Power button to select. Android will begin clearing your phone’s data so just wait.
When it is finished, go to “reboot system now” and press Power.
