Connecting a laptop with a desktop
If you want to connect 2 computers with different operating systems or with the same platforms using Local Area Network [LAN], it is very possible.
You just need to properly install the devices on both computers including their respective network cards. You also need to configure both computers’ network card’s IP addresses so they will be able to recognize which is which.
And you need to use a hub where you will connect both computers. If you don’t know how to configure a network card, you can search the web on how to properly configure a network card including how to properly assign an IP address.
If you don’t want to use a hub to connect both computers, you can use a crossover cable to connect both computers. This is the cabling style used when networking only 2 computers.
To learn how to create a crossover cable, you may refer to Termination of Straight through and cross over cables.
Hi Dear,
It is so east task to connect your laptop with your desktop computer to transfer files.
In this setup, you do not need to have any switch or hub for to make a connection between computers.
Just take a cable (usually STP cable is used) and make it cross cable.
The process of making a cable is to fix the jack on the both ends of the cable.
After this, attach this cable to both computers, this cable will work as medium between these computers.
Now you can share or receive files.
I hope you will like it.
Thanks
