Connecting Laptop to Internet via smartphone without any wires
Hello! I am using HP Elite Book 8470 p and I want to connect to internet on this laptop by using my smartphone. This is required without the usage of any sort of wire. Internet connection should be wireless. I use 3G Internet on my mobile phone and I want it to be on my laptop as well. How is it possible? What changes are required in my smartphone settings?
Answered By 0 points N/A #182179
At first, open settings on your smart phone and then go to more option and then select tethering & portable hotspot and then turn on WiFi hotspot and also turn on your mobile data connection. Now your smart phone is a WiFi hotspot. Now search, WiFi for your laptop and connect to your phone, WiFi, and it's done.
Answered By 590495 points N/A #311113
You can share the internet on your Wi-Fi-enabled phone with your laptop. Since both devices support Wi-Fi connectivity, this type of connection sharing is very easy to setup. To share your Android phone’s internet connection, you need to convert it into a Wi-Fi hotspot. When a Wi-Fi hotspot is created, your laptop can connect to the internet via the hotspot your phone created.
To do this, on your Android phone, turn on the Wi-Fi connection then connect to your Wi-Fi network. Once your phone is connected to your home Wi-Fi, on your phone, go to “Settings” then under “Wireless Networks”, tap “More”. Next, go to “Tethering and portable hotspot” then “Wi-Fi hotspot”. If this is the first time you will use it, go to “Set up Wi-Fi hotspot” then configure it.
Under “Network name”, enter the name of the hotspot. Under “Security”, select a security protocol like “WPA2 PSK” then enter the password for your Wi-Fi hotspot. When you are finished, tap “Save”. After this, your Wi-Fi hotspot should be turned on automatically. And that’s it. Just connect your laptop to the hotspot you created and make sure the password is correct.
