Connecting my laptop through wireless connection
I want to connect my laptop through wireless connection. But I don’t know how to activate my connection. Could you please help me on how to process the activation of my wireless connection?
Should launch control panel in selecting the “start” and “control panel button”. Choose the Network and Internet. Select Connect to a network. Choose your “wireless router network” from the list of accessible networks and then click “connect”.
Enter the security information if necessary to complete the connection.
It has a necessary recommendation to use a wireless network that contains certain measure of security. You must consult your router owner manual for instructions on how to complete this process.
Is this possible to connect my wireless connection just by me? Or need an expert because I don’t aware in everything regarding to this wireless etc.
Yes it can be. Like the answer of expert1 just follows the steps and read also your handbook procedure if you have it usually attaches in the gadget. For instance use an application called the WLAN Card Utility. Because some are established wireless connections and might contain an application to use.
Yah you should follow the step by step procedure to fix your problems. Again, you must launch control panel in selecting the “start” and “control panel button”. Choose the Network and Internet. Select Connect to a network. Choose your “wireless router network” from the list of accessible networks and then click “connect”. I sometimes they ask the security information. Enter it if they asking.
Thanks guys for the instructions that you gave me. It is very helpful for me, and now I will proceed to it. Again, thanks for the assistance.
