I have a virtual Widows 7 and I would like to know if its possible to connect to the root for administrative purposes for the virtual widows 7? Does the Linux environment support the administrative share of the widows PC? How else can I get full access to my windows 7 over the network?
Connecting to the root of a Virtual PC hosted in Linux
If I understand your question, you would like administrator privileges on a virtual Windows 7 machine. You would also like to know what support linux has for manipulating such a setup. If you are the administrator of the host machine, you should be able to grant yourself those same privileges on the virtual machine. Linux capabilities for the Windows environment depend on what you specifically would like to do. Since you have not provided that information, I cannot give you any further information. Another way for you to manage your system remotely would be to utilize bundled software for that specific purpose. It would be software that was different from standard server tools. It would be end user, guided software. Consult your bundled guides for remote desktop management.
