Connecting Samsung Galaxy S II to PC
I brought a new Samsung Galaxy S II. I tried all my level best and all the ways to connect Samsung Galaxy S II to my Personal Computer. What is the way to connect with?
Hi Rydersalvadorr,
You don’t have to download New PC Studio or Kies to connect your Samsung Galaxy SII to a Computer. Just insert a micro SD card in your Samsung galaxy SII and plug in the USB lead in the computer. Change the settings in your Samsung galaxy SII. Go to Applications, select Settings then choose Wireless and Network. Select USB Utilities. Next, it will says USB Mass Storage. A green android will appear then select Connect USB Storage. The android will turn to orange denoting that you are already connected to your computer. You can now move files, delete files, put music and videos, pictures and sort out all your files in your Samsung galaxy SII.
Joan Moesca
No matter how hard you try, there’s no way you can connect your phone to your computer without its own PC application called Samsung Kies. Your computer will not be able to recognize your phone whenever it is connected without this software. Just select which version of the Samsung Kies available on the page is compatible with your phone.
The latest Samsung Kies supports Windows XP, Windows Vista, Windows 7, and Windows 8.x. Microsoft Windows 10 is not yet officially supported but you can try if you are using this operating system. It requires 2 GHz or faster Intel Core Duo or equivalent processor, 1 GB RAM, 500 MB hard drive space, 1024 x 768 screen resolution, Microsoft .NET Framework 3.5 Service Pack 1, Windows Media Player 10 or higher, and Microsoft DirectX 9.0c or higher.
Additionally, here are the specifications of your phone. Samsung Galaxy S II is a 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was unveiled to the public on February 2011 and released on April 2011. It measures 125.3 x 66.1 x 8.5 millimeters and weighs 116 grams. It uses mini-SIM card.
It has Super AMOLED Plus capacitive touchscreen display with 16M colors at 480 x 800 pixels screen resolution. It supports multi-touch protected by Corning Gorilla Glass with TouchWiz UI 4.0. It ships with either Android 2.3.4 Gingerbread or Android 4.0.4 Ice Cream Sandwich upgradable to Android 4.1 Jelly Bean powered by Exynos 4210 Dual chipset, Dual Core 1.2 GHz Cortex-A9 processor, and Mali-400MP4 GPU.
It supports microSD expandable up to 32 GB. It runs on 1 GB RAM with internal storage available in 16 GB and 32 GB capacities. The primary camera supports 8 megapixels with f/2.6, LED flash, and autofocus featuring 1/3.2″ sensor size, face and smile detection, geo-tagging, and touch focus and supports 1080p video at 30 fps. The secondary camera supports 2 megapixels.
It has 3.5-millimeter jack featuring active noise cancellation with dedicated mic support; Wi-Fi 802.11 a/b/g/n with dual-band, Wi-Fi Direct, DLNA, and hotspot support; Bluetooth 3.0 with A2DP and aptX support; GPS with A-GPS support; stereo FM radio with RDS support; and microUSB 2.0 USB Host with MHL TV-out. NFC is optional. It has built-in accelerometer, gyro, proximity, and compass sensors.
The preinstalled web browser supports HTML with Adobe Flash support. Java is supported via Java MIDP emulator. It runs on removable Li-Ion 1650 mAh battery with standby time up to 710 hours on 2G and 610 hours on 3G. Talk time is up to 18 hours 20 minutes on 2G and 8 hours 40 minutes on 3G. It is available in black, white, and pink colors.
Notifications
