Connecting to tConfig server ERROR
Hi buddy,
I am getting an error every time i try connecting to tConfig server and the computer is running under Hamachi and working fine as a single player, but the problem is that, when trying with multiplayer the application keeps getting crashed and error messages keeps appearing . Kindly help me in solving this issue.
Thank You.
Answered By 590495 points N/A #151749
To avoid any problems, be sure that when in multiplayer all the participating computers are all using the same version of Hamachi. If you are using an older version of the program, try upgrading it to the new version.
I’m not sure if this is the latest version but you can download Hamachi 2.1.0.158 from https://hamachi.en.softonic.com/. This application was updated last February 6, 2012 so I think this is the latest release of the program. This version of Hamachi works with Windows 2000, Windows XP, Windows Vista, and Windows 7.
Be sure that your computer has plenty of available RAM when doing the multiplayer session. You can also try checking your computer for any possible errors. Use a disk utility application to check the system.
