Connecting To Various Services Using Sync Outlook 2013 Calendar With Google Accounts Or Google Calendars.
How can we Sync outlook 2013 calendar with the google calendar or any google accounts? How does the sync mechanism work in this scenario?
We can sync the outlook account with google account or google. To do so we need to have the google account first and the google calendar.
Then we can add and make some settings to make the google accessible through the outlook account.
To do so we need to go through some steps:
Step 1: Go to Google calendars.
Step 2: Select the calendar which you want to sync with the outlook calendar.
Step 3: Go to calendar settings.
Step 4: In Private address click on the icon.
Step 5: copy the link which is shown.
Step 6: Go to Outlook calendar.
Step 7: Go to tools.
Step 8: Go to account settings.
Step 9: Go to internet calendars.
Step 10: click on new.
Step 11:Add the link in the box. Then click theadd button. You can name your calendar there.
Step 12: That’s it the calendar is step up with the outlook and google.
You can either switch the calendars side by side or you can even add it to the outlook calendar.
But remember it is one directional sync. If you update your outlook calendar it won’t update the google calendar.
This is how the sync mechanism works with the google and outlook.
In this scenario, the sync is one directional.
