Bryan James 30 points N/APosted on - 09/30/2012
Hello experts,
The connection between VB 6 access 2007? I preferred using VB 6 programming language because it is light and not that complicated to use but still I have to study all the new updates and some sample codes regarding the connection to ms access. I hope you can help me regarding the connection between VB 6 access 2007.
As I searched Google, I discovered that there is a lot of possible answers for your concern. I have attached links of sites that provides some step-by-step procedure in connecting VB6 to MS access 2007.
1....
