Hello, whenever I am trying to transfer data to psp and trying for internet connection I am getting a message that is telling me that there is ‘error in connection’ with a code 80410B05. During troubleshoot I didn’t find any solution for this problem. Looking for some help that can take me out of this problem. Thanks.
Connection error with PSP during data transfer
Hi, Carol Troester
The reason you are getting this error is due to something has gone wrong with the MAC address of your Wi-Fi card or LAN card. It could be because of some hardware changes done to the PsP board, or if someone manually changed the MAC address. The worst case scenario can be that your Wi Fi card has malfunctioned and need to be changed (In this situation I am not sure if you can get a separate Wi Fi card for your PsP model- But there is a workaround called external Wi Fi Antenna- Try searching for it if below mentioned solution does not work)
Now in order to correct this problem please download the utility called N00bz! – MacFixerUPDATED.zip from the following URL:
com_remository/Itemid,com_remository/Itemid,0/func,startdown/id,24/
Unzip it and run.
This should solve your problem.
PT
