dwayne hunt
Posted on - 02/13/2012
Hi guys. I run SQL Server 2011 or also called as Denali CTP 1. Just today, I encountered an error when attempting to connect to SQL Server 2011 through SSMS.
The error is posted below.
Cannot connect to KodyazDenali
Additional information
A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct, and that SQL Server is configured to allow remote connections. (provider: SQL Network Interfaces, error: 26 – Error Locating Server/Instance Specified) (Microsoft SQL Server)
When I tried to open the Services Management Console to verify if SQL 2011 is still running, the SQL Server Service stopped instantly. It gave me an error when I launched SQL engine service.
Windows could not start the SQL Server (Denali) service on Local Computer.
Error 1067: The process terminated unexpectedly.
What should I do with the following errors?
Connection Error in Running Denali CTP 1 SQL Server 2011
Hi
The problem you are showing is not related to your MySQL server it is basically in the coding problem and the version you are using facing this problem so there are two option for this you have you check these two options:
1) You need to check whether your MySQL coding is fine or not if not then check where is the error if you find the error in the line then fix that bug or error if not then you need to ask some experienced person to see where is the error in which line. Then ask him to fix that error and your MySQL database will be running enough good.
2) You need to check the database version you are using as a server of MySQL is fine with the server you are using or not. This is one of the big problem with MySQL check whether the MySQL database is compatible with the server version like if you are using php then it should compatible with the php version you are using otherwise you need to check which version of MySQL database is useful for the php version you are using
These are the two options you have to check and verify and your problem will be solved in this manner.
