I am getting this error message Connection failure with computer (MH59504).
First time I saw this type of error. What is this?
The complete error message you can see in the below attached image.
Please help me to resolve this problem.
Details
There was no endpoint listening at
Net.pipe://mh59504/Connect/Service/IndexingService/that could accept the message. This is often caused by an incorrect address or SOAP action. See innerException, if present, for more details.
The pipe endpoint
‘net.pipe://mh58504/connectService/IndexingService/’ Could not be found on your local machine.
Hello
Computers connection can be interrupted from time to time.
There are a number of factors that may result in this.
Some of them may be known to us, whereas another may be complicated.
Relax.
It’s pretty simple to solve this problem.
Here are some tips
You can check out whether your computer has conflicting IP address. IP address to computers on a network must be unique. So ensure you change to another one in such scenarios.
If you are using the wireless network to ensure that you are within the coverage area.
Ensure that your internet you have permission for your Internet Service Provider.
If you are using a cable network ensure that your cable is well plugged.
I hope this will make your life easier if you follow.
If you incur problems you can visit the link
