Davis Avon
20 points
Posted on - 09/15/2012
I am unable to understand Mac application, especially its mail functions. I need to response a mail urgently. So I decided to add html mail responder in osx mail so that I can reply others easily. But do not know how to connect. What is the procedure to make connection between html mail and osx mail?
Connection of html mail responder in osx mail
It is very easy to create an email in Mac. In the beginning you may feel a bit difficult but as you get used to it, it will be a lot easier. Just follow the steps given below:
1. Create the html page of the email that you want to send.
2. You can use dreamweaver for creating the html page. It is similar to typing an email in notepad in Windows.
3. Then upload the html page to your server. If you want to add images to your email you have to upload them too.
4. Then open your web browser and add the html page to it. Type in your contact's email address.
5. Send the email you uploaded to your server.
Hope this information helps you.
