ariel chu
20 points
Posted on - 03/31/2012
I need to use my monitor with DVD player. Now I do not know how to use them together and I need to know the process how to sync them together. Kindly someone help me with the process so that I can use them together.
Ariel Chu
Connection manual solution required – problem with dvd
If you want to use your desktop monitor for your DVD player, it is very possible. I’m not sure if all DVD players include an extra monitor connector at the back but most of the DVD players I saw are equipped with this device at the back. This is very useful if your TV is not available for the DVD player and you want to use your desktop monitor for the DVD instead.
This is what you should be looking at the back of your DVD player. This is the port where you will connect your monitor’s plug.
