I have installed AVG free edition in my PC. After rebooting that, the internet connection gave this error “A connection to the remote computer cannot be established. For this connection, You may need to change network settings”, when I tried to connect Telstra Turbo card Manager.
Help me please.
AVG Antivirus software resists your PC to connect with other computer. This is a normal phenomenon for Antivirus software. You need Antivirus software to protect your PC and to save your data from unauthorized access. If it is not so you need not to install Antivirus software isn’t it? If yes then it is a great performance of your Antivirus software. Your action in this regard will be to direct it as per your requirement. Now look into Windows firewall and other defender applications whether permit you to access internet of your PC. Set your network settings as you desire.
I hope you understand it.
