A connection with the server could not be established
Hello Whiz,
When I try to open the game maker I got this error message. The download and the installation are perfect. But the problem is with the registration, it is not accepting the key. I checked the internet connection it is working well. What might be the cause? Is anti-virus is blocking this process? Please help me to resolve the error. Thanks.
Game_maker
Download Error: A connection with the server could not be established
Answered By 590495 points N/A #192494
Since the error is pointing to a problem in the download, it is directly associated to your internet connection. But to make sure that you are using the legit copy of the program, download the latest version from Download GameMaker Studio. Uninstall the one installed on your computer and restart your system. Next, run the newly downloaded installer to install the latest version of GameMaker Studio.
This version supports Windows XP, Windows Vista, Windows 7, and Windows 8. For Mac users, it supports Mac OS X 10.6 Snow Leopard and higher. For Ubuntu, it supports Ubuntu 12.10 and up. For iOS, it requires iOS 4.3 and up. For Android, it requires Android 2.2 Froyo and higher.
Once installed, try entering your license key to see if it works. If your license key is valid, it should unlock the program and access the full features. If you still can’t register with your license key, your code might be invalid. Visit the GameMaker Studio Official Website and contact support regarding your invalid license key. But even if you can’t use your license key, you can still use it in trial mode but with limited resources.
