Hello experts,
Constant guard protection suite error problem. I need this constant guard protection for my windows xp operating system, to protect my registry from other malicious ware viruses that may damage my important data and files. But the problem is I cannot get any update, give me some ways to get some update for my constant guard protection.
Thank you.
Hello Stephen,
One way to update the constant the constant guard protection will be to just open the updates and then under "Tools" look for check for updates and then run it. If you have a connection to the internet, the app will look for the most recent updates online and install it. You can as well update the app by running the windows update.
Nicke
I suggest you to get an updated copy of that application from xfinity.comcast.net. If you are an XFINITY customer, you may want to download it because it is available for free for online customers of XFINITY. But since you are still using Windows XP, I would suggest that you upgrade your system to a newer version.
There are a lot of security settings available for newer operating systems, which will lessen the need for third party software.
