Contacts not synching between Nokia E63 and Ovi Suite
I need your assistance, please.
I bought a new PC and so I was synching my phone’s (Nokia e63) contacts to Nokia Ovi Suite 3.1.0.91.  I already tried restarting MS Outlook and Ovi Suite but still my contacts wouldn’t synch.  So, how should I perform the repair?  Do I need to do this?
Hope you can give me simple steps to follow.  Thanks.
Contacts not synced
There was a problem with syncing your Contacts.  Please restart Microsoft Outlook.  If this does not help, try restarting Nokia Ovi Suite.  If the problem still persists, repair Nokia Ovi Suite.
Error code: 80043ab4
Answered By 5 points N/A #88397
It may cause failure of synchronization if there is not enough free ‘phone memory’ to store the contacts in your phone. Please check the available phone memory with File Manager application: Select Menu > Applications > Office > File mgr. Check the free space available in C: Phone memory. If the phone memory is almost full, delete some data or move the data to E: Memory Card. Then try sync again.
If it fails then try the option of Repair Sync (select Sync> Repair sync) first to fix it. Please update the OVI software to its latest versions to get many bugs fixed. Re-installing your device software may help fixing this problem.
