How do I make ContentFull content management software search functionality to work? I have been trying to use the ContentFull business management app search features for days now without any tangible result, the soft search function supposed to be working but whenever I use it, it seem it Is not working as it supposed to be. How do I address this issue?
ContentFull search feature not working.
Hello James D costanza, Â If you are facing such type of problem then you have to firstly update the app. If after updating you face similar problem,then there may be fault in internal setting. Put the VPI value within 0 and 35. Fix this error and your software will up to the task. If you want to register issue and want to discuss with software technical team then go to this link.https://www.contentful.com/about-us/
