Control the Amount of Disk Space Used by System Protection
Hi Sudesh,
You can always control the amount of disk space where you install your protection, just like using Deep Freeze program you choose either drives you want to protection or all drives you want to protect. In my internet cafe i used to protect all my drives so i can sure there will be no virus attacking my systems.
If you where using it on your personal computer then much better to choose drives where you want to be protected so that anytime you want to save files then you can save right away, if you freeze all your drive then it hassle in your part because every time you want to save files, then you need to restart your computer before you can save it.
Even if you have a Deep Freeze file, it is necessary to have an virus scanner, because Deep Freeze program alone can't guarantee a safety on your system.
Thanks,
Tony Stevenson,
Step1: Open the control panel and click on System Icon.
Step2: Click on the System Protection link.
Step3: Close the System windows.
Step4: Click on the available “hard disk drive” or “partition” that you want to change the system
protection disk space usage.
Step5: System protection needs to be turned on for the selected disk to able to adjust its disk
space usage.
Step6: Click on the configure button.
Step7: Adjust the max usage slider to how much dusk you want system protection to use for
restore point for the selected disk.
Step8: Click OK button and OK.
or
Step1: Open the start menu and right click on computer.
Step2: Click on properties.
Step3: Now click on the system protection.
Step4: In the system property window highlight the disk you want to configure.
Step5: Click on configure button above the create button.
Step6: In the system protection for local disk window use the slider to adjust the space allocated
on the selected disk.
Step7: Click on OK and OK.
