Control One Computer To Oter PC Through PC And Teamviewer?
In Computer lab, we always sit on our seats and save files in different folders. There is the same situation sometimes in the library. How can I control another computer from my computer?
Method 1- Through PC
Step 1: Enable Remote Desktop.
Step 2: Click on the Select Users button and then on Add button to add the users.
Step 3: Press Windows key and Pause to find the computer name.
Step 4: After opening the Control Panel, select Power Options, then “Change plan settings”. Disable Sleep Mode and click on Save Changes.
Step 5: Select the Start menu and open “remote desktop connection” in the search box. Enter system name and password. Click on Show Options and then on Connect.
Step 6: To allow connection to the internet, open port 3389.
Step 7: With the help of a smartphone or tablet, connect to a remote desktop.
Method 2- Using TeamViewer
Step 1: Download and install TeamViewer.
Step 2: After this “Unattended access” will start.
Step 3: Create an account.
Step 4: It will get connect to the computer remotely.
