Ashling
Posted on - 11/18/2011
Will it be possible to control and change the settings of the audio volume in my computer’s timeline? I wish to play all the music clips in the same level of volume. But I have to resize the content because there is a long default duration. Can you please help?
Controlling and changing the settings of audio volume in computer’s timeline
Hello Ashling,
Below are the procedures on how to chnage or adjust the volume of your computer timeline. It's kind of different than what you think but atleast it is very effective:
Using Avid Express Pro Use the N key on audi clip
You can also add a key frame using apostrophe or quote keys
Add and move the key frame down or up so that you can control the volume of every clip in timeline
Enable A3 and A4 tracks
Make sure that your AUTO GAME is also enabled
Those procedures are very effective so I am conficent that it will help you fix your problem. Do not hesistate to contact me if solutions I gave you doesn't work for you. Have a great day and good luck!
-Zorian
You need to make a playlist of your files and then you need to play it on your computer. Once you have a playlist it is easy to maintain the sound the duration and tracks as they will play over a period of time. Once you have a playlist then you can arrange you playlist files. If you have program such as windows media player then if you have a playlist option then you can create a playlist and all the songs will play in a sequence and you will be able to play your playlist as your require to play it. The other way is that you install jet audio in your computer and then it will be easy to maintain you list.
Michal joran.
