Convenience in using Applications already available
Does using already available applications hasten the work-ability and convenience for the employees of a company?
Hy,
You can use Microsoft Office 2007 or Microsoft Office 2003 software for this kind of job which you mentioned in your above question. You can easily manage or customize your employers data in MS excel program. You can create a spread sheet with your employer’s data and then you can customize later that data by access your saved file.
If you want to make any presentation for the training or other purpose, then you may use MS power point application from the MS office software.
You can write any document or any research in MS Word application. Here you can customize your document easily.
So may be Microsoft Office program is the complete solution regarding your issues.
Thanks
I’m not sure what applications it is you are referring to since different companies use different software to do different tasks for their productivity and overall operation. But, of course, there are similarities with the software they use like for example the one mentioned in the post above, the Microsoft Office. If a company does not require latest functions of the software and only relies on processing different office documents then I think they will be comfortable with older versions of the product like for example the Microsoft Office 2003.
But, of course, if a company wants to experience an optimized task and benefit from it and makes it for the employees to do their task much faster, then upgrading to a much higher version like Microsoft Office Enterprise 2007 would still be an advantage. Other higher versions are already available. Just check with your software store. And don’t forget some accounting software that can help automate any accounting job.
