Conversion With Ease: Convert MOV To WMV Free
Hi. I want to learn how to convert MOV to WMV free. What is the use of converting the format of the files? Can you please suggest me steps to do the same? Also, is there any software available online? Thanks in advance.
Answered By 250 points N/A #115957
Hi. First of all, the use of converting the format of the files is to make them compatible with the Windows-based devices if the required plug-in is not installed. For this, an MOVavi Video Converter is needed which converts files from the MOV format to the WMV format. The steps to convert MOV to WMV free are as follows-
1) First, download the MOV to WMV converter from the website and once the download completes, double-click to open the software and follow the steps given to complete the installation.
2) Now, the videos that need to be converted should be browsed from the desktop by clicking on the option add video. There is an added advantage with the software that is, multiple files can be converted at once.
3) Next, open the list of formats in which the file needs to be converted and among the options, click on WMV. Then, select the resolution suitable for you.
4) Select the folder in which you would like to save the converted file in the destination folder.
5) Now, to start with the conversion, click on convert button. The progress can also be checked in the progress bar which appears on the screen.
6) Close the window.
The software to perform the action can be downloaded online as mentioned above from websites such as download.com.
Hope we helped.
