Conversion of files of Office 2007
What is the way to open a Microsoft Word document of Microsoft Office 2007 in Microsoft Office 2000 program
Which is most commonly used by us?
To convert any Microsoft Word document from version 2007 to version 2000, just do the following:
6. Download the Microsoft Office 2007 Compatibility Pack from Microsoft’s website (Download Center) which is free for all users of registered Microsoft Operating System
7. Have the compatibility pack for Microsoft Office 2007 installed on your computer
8. Adjust the language settings that may change due to the installation of the Compatibility Pack
9. Open your DOCX or DOCM file in Microsoft Word 2000
Hey buddy, If you are using Microsoft Office 2000 but want to open a document in Office 2007 format that won't really do.
You cannot open a higher version file format in a lower version. You will have to find a compatibility format or a file converter.
Here is my tip for you. Please follow step by step.
Then that's it. You're good to go.
You can enjoy opening and even saving your files in higher version.. the Microsoft Word 2007..
I hope that helps.
Let me know.(^-^)
You need to install the Microsoft Office Compatibility Pack.
It is not exactly an upgrade to your Office 2000 but it will enable your older version of MS Office to recognize, open, and edit Microsoft Word 2007, Microsoft Excel 2007, and Microsoft PowerPoint 2007 files.
Office 2007 files are those saved as .docx or .docm (MS Word 2007) and .xlsx (Microsoft Excel 2007).
Take note though that even with the compatibility pack, not everything from an Office 2007 document can be edited in older versions of MS Office.
Some of the advanced features of Office 2007 simply cannot be edited in Office 2000. Read more about it here:
