Conversion of PowerPoint Presentation to other formats
How can you convert your PowerPoint presentations to other formats so that you view them on your vcd player or in Windows Media Player?
If your presentation is in power point then you can’t watch that as video, until or unless, you convert them to AVI or WMV. There are many free powerful tools are available online, that converts these video for free.
Byte scout is very famous in this regard. IF this software is installed on your computer then by simply going to file menu and click, convert to AVI.
Then step by step different windows come and after few minutes your presentation will be converted to video mode that can be run on media player.
You can use a software called the Acoolsoft PPT2Video Converter to convert your PowerPoint presentation into video formats using the following procedure:
Carl
