Conversion problem with the video
I watch some local funny tv shows in the YouTube and i want to burn it so that my parents could watch in the television.
Hi Jack,
I hope you are in your full swing, enjoying your life. The question you ask is a problem that happened with me as well. I came across this problem, the reason I found behind this problem was that I was using an unlicensed package of video converter, which did not process the whole video and even though when it was completed it showed the same kind of error you described in your question. The solution to your question is that try using a purchased license software or download Free Convert to DIVX, AVI, WMV, MP4, MPEG Converter on CNET website.
I hope you will surely try this to get your problem solved. Â
Thank you
Check your DVD settings first of all it may be causing some problem. If you are converting a file form one format to another format then you need to check that you are using the right way to convert the file. Also check that the convert settings are configured correctly and there is no option selected for increase of speed.
Here I need to know what convert you are using to convert your files. Any how there are many converters with helps to convert files such a converter is TOTAL VIDEO CONVERTER and you can convert your files in this program from any format to another format. It is easy also you can change your converter also i allows you to burn your DVD or CD. You can try this program and then you can convert your files.
Now once the file is converted check your DVD player options that they are not set to fast speed for fast forward, if you found any problem you can change the settings as per your requirements and it will work fine. I hope you can now solve your problem.
Karen cruise.
