Conversion of Songs From Cassette Tape To CD or MP3 Files
What are the devices and how am I going to convert the songs from the cassette tape to CD or MP3 files?
The task to convert a cassette tape to a CD or MP3 files is quite simple.
These are the steps you can follow:
Requirements:
1. Stereo cassette player.
2. PC and a CD burner.
3. 3.5mm jack male stereo audio cable.
Ways:
1. Connect the cassette player to the microphone or the line in ports on the sound card of your PC.
2. Then use the Windows wave recorder to record the sound.
3. Then download free sound editing software audacity to split the large .wave file to several MP3 files.
4. Then use Windows Media Player or I tunes to burn a CD.
Caringal Cheong
It is too easy to convert a cassette tape to a CD or MP3 files you will need few things a Stereo cassette player aPC and a CD burner. And 3.5mm jack male stereo audio cable.
First connect the cassette player to the microphone or the line in ports on the sound card of your PC and then use the Windows wave recorder to record the sound.
Now download the free sound editing software audacity to split the large and wave file to several MP3 files.
And at last use Windows Media Player or I tunes to burn a CD.
