kollenabril
10 points
Posted on - 08/11/2011
hi !
I have a short Flash animation in Adobe Flash CS5 Action Script 2.0 for my introduction. i have also an animation in Adobe Flash Action Script 3.0 for the content of my presentation. When i inserted my introduction that has an Action Script of 2.0 in the content animation that has an Action Script 3. 0. the introduction will not work…
please help me. i don't know what to do…
Convert Adobe Flash CS5 Action Script 2.0 to 3.0
So how does that work if you are replacing any permit? Will that mean you must purchase downright multiple licenses regarding exactly what is apparently the most expensive kit of software about? Appears a little ridiculous. It isn't just like Adobe will be losing money, you cannot acquire CS3 any more, they should permit the opportunity to help save inside reduced formats!
Over a bit diverse subject, the reason why can not CS5 save the CS4 record because CS5? I have just submitted a forum upward, like me having large issues. After i open up any CS4 document, and continue to help save it as CS5 Flash failures.
