Hello Everyone
I am using Mac OS X 10.7. I have a few audio files .rm format. I am looking for a software which can convert real audio(.rm file) into mp3 format. Anyone tell me how do I convert .rm file to .mp3 on Mac?
Suggest me some software for Convert audio from rm file mac. While sharing the information, do tell me if the application is freeware or a shareware?
Thanks
Convert audio from rm file Mac?
Hi Jeffrey,
To convert .rm file into .mp3 format on MAC, one can use iOrgsoft  MP3Converter for Mac.  It is a powerful RM/RMVB batch converter that can convert real audio files to mp3 on MAC.
There are many advantages of using this over the other software available and are listed below:
1. One can use this to convert many rm files into mp3 at the same time using the batch feature.
2. Another salient feature is that it can trim rm files, removing silent or unwanted parts.
3. Can extract audio from real audio as well as real video files.
It works on Mac 10.4-10.6(Snow Leopard). Also, it is shareware, available for $29.95 at the following location:
http://www.iorgsoft.com/MP3-Converter-for-Mac/
You can also try the free trial (Available at the same location) to see if this software meets your needs which ideally it will.
