Convert cad to arcview Arcv2CAD 6.0 converts ESRI shapefiles
Convert cad to arcview Arcv2CAD 6.0 converts ESRI shape files (ArcView, ArcGIS, ArcMap etc.). Does it mean that this allows shape files to be read by virtually all CAD software? What are features of this converter?
Answered By 15 points N/A #186154
Hi Joseph,
The features of Convert cad to arc view Arcv2CAD 6.0 are as mentioned below:
1) It is a standalone CAD shape file conversion
2) Translates all AutoCAD DXF and DWG versions
3) Provides optional translations to 2D and 3D shape files
4) It attaches Z value as elevation data
5) It provides data suitable for import to Google Earth Pro
6) It has option to output raw data like CAD to XYZ, CAD to CSV
7) It translates 3D surfaces to multi patch shape file types
8) It translates holes, islands from originating CAD drawing to polygon shape file
9) It provides filter by Layer, Area, Color, Entity
10)It has option to provide text to label theme
