Convert clinical photographic to digital photographs
There are two ways to do it. the first one is a method applicable to all but has a effect of quality. That is you go to a shop that develops you side roll films. and after which you scan the pictures that way it is already digital. The other method is by doing a direct process of side roll films to digital. but this process has limitation as well. not all side rolls can be converted to digital, one good example is the 35mm film single-lens reflex. What i suggest is that you to go Photoshop stores and ask them if they can convert your rolls to digital.
