Convert excel to web pages
I'm working with a project right now. I need to convert excel to web pages. How to convert excel to web pages?
Can you please help me?
Thanks!
Thanks!
I am currently using MS Excel 2003, but the same procedure applies if you are using another version of MS Office.
In order to convert your excel spreadsheet into a web page, just follow these simple steps:
I hope this helps!
This how to convert excel to web pages, first open your excel application and open your existing file, click File > Open, then select a specific content by using your mouse by clicking and dragging on it from the area such range of cells that you want to publish on the web page, then click Save As option or clicking the Microsoft Office button to bring up the dialog box. Choose web pages option using the Format drop down menu.
After that click the Workbook , Sheet or Selection option, to specify the specific data, that you want to publish on your web page, then click Web Options to specified web page elements, the title and the key words.
Click some various of tabs and enter or select your other preferences from the menu, then click Ok if you're done.
To save, click Save button to record your selections HTML file.
You must place the file from other supporting files on your web to publish your excel as a web page.
Notifications
