Ealdwine
10 points
Posted on - 03/05/2012
I have a PDF file to edit. I also have to change the format before making change in it, so I am looking for a website where I can convert this file to doc format. I am not keen to download any software. Does anyone know such type of site?
Convert this file to doc format from Pdf.
Yes, you're right. To be able to convert such a pdf file, you will have to convert it first to word (if it is a word document converted to pdf).
I've found this link https://www.freepdfconvert.com/
It converts pdf to file or file to pdf like word, powerpoint, excel, images and other files.
Just attach your file to be converted or you can enter the website, and then enter your email address (because it is where they will send/attach the output of the file).  After few minutes check your email address, if it isn’t yet sent to you, wait for few minutes.
I hope this help. You can ask again if you have questions.
