Convert image of MrSID to ECW format
Hello Techyv Experts, I would like to convert one image of MrSID to ECW format without having a negative impact on the quality of the image. The size of the file doesn't matter as the quality is prime. Please guide me the process of doing the same. Waiting for an expert solution. Thanks
Answered By 40 points N/A #159857
I found a good application for you.  It's called the ECW Compressor.  This application is basically intended for compressing ecw files, but it also has the option that you need for converting extensions. It is really easy to use, just import the file you want to convert, and press the “Convert” option, select which format you want to use, and press “OK.”  Also, on the previous link you can download the manual, which will help you to fully understand this application.  Regards.
