Convert img to iso win
Hi Experts,
I am trying to convert the IMG to ISO win. I am looking for software for IMG to ISO win. Please send me the full software link for IMG to ISO win.
Thanks,
Best Regards
Best Answer by Ancheta Nelson
Answered By 15 points N/A #179595
To convert from IMG to ISO, one can take two ways. Such as:
  1. Online.
  2. Offline (by using software).
There are online converters on many pages where the process is:
  • Upload the file.
  • Click convert.
  • Download the converted file.
Some such pages are given here:
Some software which are easy to use and can be used to convert, are given here:
Hope these helped you.
Answered By 0 points N/A #179596
Hello Lance Faz,
I am very happy to be helpful to you and help you in your trouble. On the online, I have found a software called IMG to ISO converter. Here is the download link:
IMG to ISO is very good and trusting software and can convert easily image files from IMG to ISO format.
The IMG is one kind of file that contains an image copy of any disk from where this file was created. Its file extension is normally “*.ima” or “*ima”. This image format ISO is now more well-liked than the image format IMG.
This software will help you to get the old image to get a totally new and familiar image copy.
The ISO format file will be created by converting using this software will make ISO-9660 format which is most familiar. This software can also be used to open “*.ima” or “*.img” file.
The system requirements in order to run this software are Windows XP/Vista and its size is also too small. It is 1.3 MB in size.
