Convert .IVR File to .WMV
To convert .IVR files to .WMV files. You have to download the software to change its format and to do this , best software would be format factory . It can be easily downloaded from the internet. After downloading it, install it in your computer. After installing it ,open it, after opening it, a window will be opened on your screen. on the right side of the window there are there are different types of format. written.
Then select the format .WMV .then after selecting it a box will open, on the top of which there will be a button named add file ,then click on it then you can select the file whichever you want to convert. After selecting the files click on ok button after that a new window will open. The file name will be written there and in front of it the address will be written where the file was saved after converting. Start button will be there on the top of that window than click on that button after clicking on that button file will start converting. After converting the file you can go to the given address where your file was saved and you can run it.
Its’s easy to convert .IVR file into .WMV. You have to use an .IVR converter. IVR converter can help you to convert your IVR file to wmv, AVI, MPEG, WMV, DivX, MP4, H.264/AVC, RM, MOV, XviD, 3GP, FLV, SWF, DVD, etc. Simply go to this website-
http://www.bigasoft.com/articles/ivr-converter-player-mp4.html
Download it. Install and enjoy your converting.
