winnie zac
90 points
Posted on - 11/20/2012
I downloaded a email notifier software. But It’s default alert sound is so low volume. As a result I can’t hear alert sound. It’s has option to set alert sound but supported only wav ima adpcm mono format sound. How to I can convert from mp3 to wav format sound ?
Convert mp3 to wav ima adpcm
Hello Mr. Zac.
This is a very easy process. You can do this online. Just visit https://audio.online-convert.com/convert-to-wav. This website can convert from any format of music to .wav format. You can convert your mp3 files very smoothly. This is a automatic process. You have to upload your music file, then select the bit rate. The conversion process will start instantly. This will take a few minutes. Then you can download the converted file. You can also convert video files there.
Thank you for your question.
By using this link you can easily change the file format of an MP3 file to WAV file:
http://www.zamzar.com
They will ask you to follow some trouble-free steps and the new and remade video will be sent to your mailbox. Press the link and the video will be transferred.
Keep in mind that the WAV file is giant than the MP3 file.
Use the link for converting the format.
