Convert MS Word to PDF file
Hi there guys! I just want some help on this..
Im currently working on something using MS Word and Im planning to make it into a PDF..
Is there a software that could convert an MS Word file into a PDF..?
Hello Amscott.
I can suggest 2 ways that you can convert your Word document to PDF:
1. Use a third-party PDF converter. One such PDF converter is Bullzip PDF Printer. All you have to do is download and install it and it will create a virtual printer within Windows. When you want to convert a document (Word, Excel, another PDF, Powerpoint, etc.) to PDF, all you have to do is print whatever document it is to the Bullzip PDF Printer. Bullzip PDF Printer is free and its output can be customized.
2. Use OpenOffice or LibreOffice Writer to open the Word document and use the PDF export function to create a PDF file.
You can read more about LibreOffice Writer here:
https://www.libreoffice.org/discover/writer/
Hope this helps!
Hi Amscott,
Yes of course there is. Since the internet started "breathing" everything is here, every information, software and news you can possibly want.You can turn your Microsoft Word document into Notepad, into PowerPoint, into HTML, into Excel,into IEEE format, into WordPerfect, seriously anything you would like.
Okay, now I suppose you asked this question in order for a proper solution with a program or address to help you convert it. You have only two simple choices, you either do it online, on a website that deals with converting such documents, just write up on Google Convert Microsoft Word into PDF online and you will get a million answers and websites with such methods. The second, you type the same thing without the word "online" and search for a program to convert it.
Now to explain what's the difference between both.Online converting is risky because you can download viruses which can mess up your computer, but if it's good is alot faster than looking up for a program. Instead, a stable program is more reliable, you always have it on your PC, you don't have to wait for the internet to load, and if your connection is down, you always have the program right there, ready for usage.
Good Luck To You, Mamangun Ceilo.
Hi Techyv wizards!
Thank you so much for the advices. Both works well. I was able to convert my file into PDF format. Using a converter.
Thanks techyv too!
Hi
You can do this in the following Ways :-
Use the Save as Function and add (DOT) PDF extension or
If you have already saved file the Just Rename with(DOT) PDF extension
Filename.doc becomes Filename.pdf
If you have some Microsoft Office Word documents that you need to be in PDF format, you don’t need a converter to do the job. You can do it right within the program because Microsoft Office Word is able to save its document in PDF format. To do this, in Microsoft Office Word, load or open your document. Next, click “File” then “Save As”.
In “Save As” dialog, set “Save as type” to “PDF (*.pdf)” then save the file. Your document should now be saved in PDF format. Another way is to use an online converter. Go to Convert documents and images to PDF. This online tool not only allows you to convert Microsoft Office Word documents to PDF format but also images.
You can even use it to take a screenshot of a website and have it converted in PDF format. The tool supports the following conversions: DOC to PDF, DOCX to PDF, TXT to PDF, and many more. You can upload the documents in different ways. You can select the file directly from your computer or upload from Google Drive or Dropbox.
You can also upload by URL if you uploaded the files on your web server. Once the file is uploaded, just click “Convert file” to start converting. You can only upload and convert one file at a time. Once the conversion is complete, the file is downloaded automatically to your computer or you can download it manually if the auto-download didn’t work.
