I am having a difficult time importing my Outlook Express emails into a .pst file.
I know there is no direct way of doing it and I’m not so techyv to figure out.
Is there someone who can help me on what to do or what software I can use in between to convert outlook express to PST?
Convert my Outlook express files into a .pst file
Hi Richard C Warner,
The only way to get files from MS Outlook that are either corrupt, is by using the network which support to open PST files program.
So you may click the open file button & select a file of OST or PST format from any local or network disk. Thereafter double check the path is correct before proceeding to the checklist on affected file and click the next button when is ready.
When you are done waiting for the end Email recovery and evaluate the results when ready.
I will give you a link for PST for free:Â http://open-pst-files-free.software.informer.com
Hi Richard,
It is not easy or in fact not possible for Outlook Express to import a perfect PST file. Open PST in Outlook, there after import to Outlook Express. If your computer does not have outlook, use another computer which has both outlook and outlook express where you can import the PST to Outlook there after import emails from there to outlook express.
DBX Converter software
Converts outlook express emails (.dbx files) to outlook (.pst files)
It is easy and efficient to use, retains the initial email format, allows emails along with key properties i.e To, Cc, BCC, from, sent and received date, attachments and supports all outlook versions i.e 5, 5.5, 6.
Download a demonstration on http://www.dbxtopstconverter.com/outlook-express-to-outlook.html
