Convert my songs in album to digital?
Hallo, which software can I use in my computer that can let me convert my songs in album to digital? Which is the best and probably not costly? Moreover, which equipment would suit my work? I would appreciate any help.
Answered By 0 points N/A #122670
There are 3 ways you can do this.
The first and easiest way is just to put an image in your desired folder and name it just as 'Folder'
The second way is add the music into the Windows Media Player Library, and after that drag the desired image into it.
The third way is to play the mp3 file in Winamp and press 'Alt+3'. From that menu, select the 'Artwork' tab And you can add And delete the artwork/images from an mp3 file.
Jetaudio is also a great way to do this.
I hope this helps you out. Good luck!
