Hello techyv.com!
I have here a Windows 7 laptop, and my boss send me a bunch of phone numbers in Nitro pdf phone number format, Now he wants me to transfer this all into words, and there were like thousands of them. I asked him if I could copypaste this all, and he says if I could then why not. So is there a way on how will I be able to convert a nitro pdf phone number into MS word?
Convert a nitro PDF phone number into word.
Hi Lucien,
You can use some pdf to word converter, you can get lots of free pdf to word converter in google search and some premium with special features. Now i give you a direction to convert pdf to word in Adobe Acrobat.
Open the PDF in Adobe Acrobat.
Go to the "Basic" > "Select Text" > "Select Table."
Highlight the Whole table with your mouse. Right-click and select "Copy Selected Table," or press "Ctrl+C.
Open Microsoft Word document and paste which table you copied from pdf.
Then save the file.
Hopefully this will help you a lot.
It is a very easy process. You don’t need any software to convert it into Microsoft Word, but you can also use different software.
1. First, open the PDF files.
2. Then, mark the number in the PDF files that you want to copy, or you can mark them all by pressing Ctrl+A.
3. Now press Ctrl+C to copy them.
4. Open a new Microsoft Word file, and press Ctrl+V to paste.
5. Edit the Microsoft Word document as you wish, and save it.
