Convert PDF file in ms-word file
I have some pdf files. I want to convert these files in ms-word file.and it won't be typed,but it will be by software. I am not founding any software to convert it. I need help. Thanks
Turn PDF to Term Application allows you quickly to change all your PDF information into Ms Term papers (. Doc), while maintaining the same quality of the unique PDF computer file, with written text and all pictures. The transformed word computer file will be quickly modified via any edition of Ms Term.
Convert PDF to Term Application is very easy to use and can convert not only in word but also in written text structure (.Txt) and TIFF (.Tiff).
You can also buy These type of software from any online store or u can download a trial version and check working out put that, is it acceptable for you or not and try other one for better result.
Most of those software are as follow:
And secondly you also convert your PDF file online from below link.
If you have a PDF file and you want to convert it to Microsoft Office Word format to avoid typing it again manually but without installing any program, try Convert PDF to Word. It is a free online tool where you can convert your PDF file into Microsoft Office Word format. This tool will convert your PDF file into DOC format only (*.doc).
If you wish to convert your PDF file to DOCX format (*.docx), go to Convert documents to DOCX. Just upload your file and convert it. You can also upload your file using URL. If your PDF file is located on your web server, just enter the URL of your file in the text field.
If you uploaded your file to Google Drive or Dropbox, you can also make the tool to fetch your file from there.
Notifications
