Convert PDF to word Hebrew character
I need to convert PDF to word Hebrew character, I use Adobe Professional for this process, but my current system doesn't have Adobe Professional.
Is there any online extraction method, that will extract the Hebrew characters to word.
Please provide the website link.
Thanks,
Adam Johnson
Answered By 0 points N/A #198674
Hello Adam,
I faced with the same trouble recently, when I had to get a PDF converted to word in the German language. Even though there are many wonderful software which do this job, the one I found pretty easy and wonderful was "PDF To Word Converter Pro"
It not only converts your pdf to word but also images and moreover it supports over 70 languages, making it easy for conversion. You can find a download link for it over here.
I hope this software helps you, like it did to me.
Mccall
