avah.hannah
30 points
Posted on - 05/03/2013
Hi guys,
I am looking for a service that I can use to convert PDF to word online mb’s allowing. Thus it should be able to handle large files and provide me with quality output that is legible and can be edited and is easy to download. I have a lot of PDF files that I need converted so it should also be able to convert PDF files in batch.
Anyone who can help me with this please reply to the post.
Convert PDF to word online
Hello there Avah,
PDF to Word Online is the best and preferred converter since you are given option if you want to try it online or for your desktop computers. You may try this converter at their website: http://www.pdfonline.com/pdf-to-word-converter/. Another one is using the nitro products. Through nitro, you can convert pdf to word online or you may buy their desktop software for pdf that lets you convert to word and you can edit the content. Click here for the link.
Hope this helps you.
Regards, Roland.
There is an online pdf to word converter that saves you from the hassle of having to sign up or enter your email address and it’s for free. Visit pdftoword.us. It offers pdf conversion to word (.doc), image and text. All you need to do is to choose the pdf file you need to convert, select convert to word then click Convert. It automatically downloads your converted file. When you open your converted file using MSWord, it would be in protected view. Just click enable editing so you can edit changes.
